Import assembly into Teamcenter
I have an ProdDef created in Teamcenter. Locally I have a two part assembly where the parts are constrained by assembly constraints. One part is already in Teamcenter. I want to import that assembly as a UG data set under the item in Teamcenter. When I do the import I select the assembly file and imports fine.
When I opened the assembly from Teamcenter (or look at the product structure) I expected the assembly to pull the mated component out of the database since it already existed in TC. It did not.
Question is why and another is can it? If I had a 100 piece assembly where some of the parts were already in Teamcenter and others where not, how would I import the entire thing?
NX6.0.5
Thanks...
NX6.0.5
Thanks...
Fighter Pilot
Manufacturing Engineer
RE: Import assembly into Teamcenter
