List of parts in assembly
I'm writting a VB journal and I need to get list of all parts and subassemblies (with subassemblies parts) in array.
Mayby sth with Public Class AssemblyManager?
Any help?
RE: List of parts in assembly
There's a utility named 'ugpc.exe' which can be found in the UGII folder of your NX install which will return a list of all of the components in an assembly.  To see the available options and modifiers simply run this utility from a command prompt window with the -h modifier and you will get the help info for what the other modifiers will give you.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
