Part List Properties
Can someone tell me which property is used to define if a part is a "part", "pipe", "pipe fitting" of "frame member"? Can I add a custom property to our own parts library, so i can filter my partlist this way?
Thx, Johan
RE: Part List Properties
I would have thought pipes and pipe fittings would be defined by the fact thay they are plaved in the piping environment.
Similarly frame members would be created by the frames environment.
Parts would be just placed normally.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
And is there a way to make a normal part act as a "pipe" or "pipe fitting", a way to let SE known that this part is in fact a "pipe" or "pipe fitting"?
I wouldn't think so - it's not that the part has any particular type, just how they are placed in the assembly.
Xpresroute would place 'pipe or pipe-fitting components, Frames would place frame type components.
bc.
Quadro FX4600.
