Expression "Center of mass"?
Hello!
When I use the "measure bodies" command Nx 7.5 automatically generates body measurements such as: Volume,mass,surface area,weight and radius of gyration into expressions.
Is it possible to also get the "Center Of Mass" coordinates like an expression?
RE: Expression "Center of mass"?
The 'mesaure bodies' feature will create a point object.
You could then use 'measure distance' from a specified point to the point defined by 'measure body'. This will create an expression.
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
Thank you!
