Different Grade Steels on Storage Tanks
Is there any problem with having 2 different grade steels on an API 650 Storage Tank?
We want to weld a bottom course of A537 and all other courses of A283 and want to know if there could be any detrimental effects caused by this?
I understand that they may distort at slightly different rates however is there anywhere where this is permitted or rejected in API 650 or any other engineering standards or specifications?
RE: Different Grade Steels on Storage Tanks
As this is not directly addressed in API 650 is there any other storage tank standard that specifically states that 2 shell courses can be of different grade steels?
Section 14.3.2.4 of AWWA D100-11, "In the interest of economy, upper courses may be of weaker material than used in the lower course of shell plates...", etc.
