7.5 Routing Electrical Formbord
When transfering my electrical routing into formboard my keyed end connectors always show up parallel and pointing the same direction. In prior version of formboard my keyed end conectors will display the end connectors in the actual angle relative to each other. Is there a way to display the relative angle of the respective end connectors with the new formboard? crude visual representaion below. using Version 7.5.2.5.
o------o- (legacy formboard keyed connectors 90 between).
-o-----o- (latest formboard rotates keyed connectors to be inline)
RE: 7.5 Routing Electrical Formbord
