Blue Tapcon Capacity
Does anyone have published data on blue tapcon screws for attachment to clay brick? I am trying to attach a floor joist to an existing clay brick chimney to reduce the span of the joist for additional file storage loading. Mechanical and plumbing runs preclude me from installing secondary framing to take the 1200# load to the concrete floor.
Thanks!
Thanks!
RE: Blue Tapcon Capacity
Contact Buildex
http://www.tapcon.com/concreteAnchor.asp
http://ww
http://www.buildextapcon.com/pdf/ESR-2202.pdf
EIT
http://www.buildextapcon.com/approvals.asp
EIT
I think Hilti has one or two anchors that are designed for brick. Check them out.
I am pretty dubious about permanent anchoring into brick. Too much happens to it - like NO maintenance.
