Exit Edit Component Shortcut?
Is there a shortcut to exit from "edit part" or "edit assembly" while in another assembly? I often edit parts while still in the assembly file, and I don't want to go up to the command manager to exit from "edit part"; rebuild just rebuilds the part (which it should). Any suggestions?
RE: Exit Edit Component Shortcut?
