COMBINING STAINLESS AND CARBON STEEL MEMBERS
We are assembling a structure made up of a combination of stainless and carbon steel members. What is the best practice of bolting together (using isolating packers or gaskets) and what bolts to use (Zink plated?)?
RE: COMBINING STAINLESS AND CARBON STEEL MEMBERS
Wouldn't hurt to have a s/s washer on the galv bolt/nut on the stainless side of the joint.
The 'spacer' can be good, well cured paint [heavy and/or partially cured paint oozes and releases the bolt tension]. Another good choice is using stainless "finger shims" or pre-punched thin plate between the members. Or you can just hot-dip galvanize the carbon steel members.
