Pipe Line Venting
Pipe Line Venting
There is a measured high discharge pressure / excessive piping loss vs. calculated (see attached - measured values in red) & believe it is due to air entrainment. It appears multiple vents only with vacuum check (no way for air to re-enter system) are needed (5 locations at risers. The vacuum check would prevent draining a high level north tank thru the vents.
The pump discharge pressure of 36 psi at 650 gpm agrees with the pump curve (system piping issue). The target for a worst case is 800 gpm at 76 ft.
I am looking for a consensus before adding the vents. Note there was one manual vent via a ball valve added already to the system but with no reduction in the system pressure.
