Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site has saved me hours of work that I cannot begin to express my satisfaction..."
Geography
akaballa (Computer)
5 Oct 11 12:01
Hi I am not sure if I am in the right forum.
I have a quick concern with the sed command.
I am trying to extract a substring from a string in shell script.
This is my code so far:
CODE
cmdRun="-vs LAST_BUS_DAY=20111005"
time_stamp=`echo "$cmdRun" | sed 's/.*([0-9])+.*/\\\\1/'`
echo $time_stamp
I just need to extract 20111005.  If this case the numbers are in the end.  But in some other cases it might be in the middle of the string.  Therefore, I chose to use sed.
However, when I run this code, It match the entire $cmdRun string.  Please advice!
akaballa
drawoh (Mechanical)
6 Oct 11 12:28
akaballa,
   This is a good forum.
   I used sed in a makefile a long time ago to replace footer text on a website.  I forget how I did it.  I read the man page at the time.  I think sed has one of those "In A Nutshell" books about an inch thick.
   I use perl to solve problems like this.  The switch command is an extremely powerful search and replace tool.
   Your operation above, is looking for a consecutive series of numbers, right?
               JHG
akaballa (Computer)
6 Oct 11 15:04
Yes my operation is looking for 8 consecutive numbers.
drawoh (Mechanical)
7 Oct 11 11:27
akaballa,
   So, you are searching for sequences of eight numbers, and rejecting any sequence with more or less than eight of them?
   Your command line above selects one character on the basis being from 0 to 9.  I don't understand set very well, but I see nothing that forces an eight character sequence.
   You have a programming problem, easily solved in C.  Probably, it is easily solved in perl, but I would have to read my book on it.
               JHG
FrankMalone (Mechanical)
13 Oct 11 4:02
with sed I think is a little more difficult because sed matches the complete line. Why not use awk?. I show you an example:
time_stamp=`echo "$cmdRun" | awk '{print (substr($0,match($0,"(19|20)[0-9][0-9](0[1-9]|1[0-2])(0[1-9]|[12][0-9]|3[01])"),8))}'`
echo $time_stamp
The regexp matches a valid date 19xx or 20xx folowed by a valid month 0x or 10 or 11 or 12 followed by a day 0x or 1x or 2x or 30 or 31.
The substr command extract the 8 digits beginning where the match command matches the date.
The output from my terminal was:
$ cmdRun="-vs LAST_BUS_DAY=20111005"
$ time_stamp=`echo "$cmdRun" | awk '{print (substr($0,match($0,"(19|20)[0-9][0-9](0[1-9]|1[0-2])(0[1-9]|[12][0-9]|3[01])"),8))}'`
$ echo $time_stamp
20111005
The time_stamp line is all a single line.
Hope this helps.
Frank.
drawoh (Mechanical)
13 Oct 11 13:36
FrankMalone,
   I am actually not sure about sed, but I know there is an "in a Netshell" book on awk, and it is very thick indeed.  If the OP has any programming skills, they should know C.  Perl is worth learning.  I cannot see myself trying to figure out awk.
               JHG
14 Oct 11 5:43
Hi JHG, I understand you, but if you need work with filters in an easy way, awk is a very good choice.
The man page about awk is only two or three pages long, there is a port to windows also.
Buy in any case is up to you, if you don't like it don't use it.
Frank.
kellnerp (Mechanical)
21 Oct 11 14:39
awk is not as hard to learn as sed.
A perquisite for either is a grasp of regex (which I am just a novice in)
sed is much more regex dependent than awk.
regex expressions for just about anything can be found using google.
For example this:
CODE
^([2-9]\d{3}((0[1-9]|1[012])(0[1-9]|1\d|2[0-8])|(0[13456789]|1[012])(29|30)|(0[13578]|1[02])31)|(([2-9]\d)(0[48]|[2468][048]|[13579][26])|(([2468][048]|[3579][26])00))0229)$
from regexlib matches 20000101 and checks for incorrect leap year dates.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
