ST4 no material table in assembly enviroment??
I used to use the material table in the assembly enviroment to automatically drive information into the draft.
For example, I would call out a casting number as the material.
It now looks like I can no longer do this in ST4 unless I am missing something. Any else run into this?
RE: ST4 no material table in assembly enviroment??
If so did you save your old material table?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
I saved the old table and have access to it in the part and sheetmetal enviroments but I dont see a way to access it in the tabs or add it to the quick access toolbar.
bc.
Quadro FX4600.
