Finding a diaphragm valve, NC manual linear operation
Help guys,
I have been looking for months for a type of valve which looks to have been superseded by solenoid automation which is causing a big headache!
The valve requirements
2 or 3 way Normally closed
linear manual action
3/4" BSPP ports (or near as)
Pressure rating ~10bar as its controlling a mains water supply
HELP!!
HELP!!
RE: Finding a diaphragm valve, NC manual linear operation
My focus: Alloy Valves Super Duplex Valves Monel Valves Incoloy Valves Titanium Valves Hastelloy Valves
What about:
http:
try also http:
This company does also have variations not easily found, try a direct inquiry.
I am not sure, but believe handoperated linear operation might be part of the program as every valve body can be equipped with pneumatic actuator (linear ?) as well as handwheel.
Both sanitary and industrial versions available.
Good luck!
