Facet Bodies appearing in Assemblies NX7.5
Hoping someone can advise me.
On opening an assembly with no child parts opened I still see faceted representations of the child parts. How can I stop this from happening?
RE: Facet Bodies appearing in Assemblies NX7.5
Now the second issue is that you might have created what's called 'Product Outline' which is a VERY lightweight representation of an Assembly which again will only appear when the Components have not been loaded. Generally speaking these 'Product Outlines' are created translucent, but they can be completely opaque like normal solid displays. If this is what you have you may notice that you're not able to select any of the 'Components', but you can toggle the display of the 'Product Outline' using the icon found on the 'Assemblies' toolbar. Actually the reason why you can't select any of these very lightweight representations is because they are automatically created on a visible but non-selectable layer (this is set in Customer Defaults). So if you wish to delete this 'Product Outline', you'll need to set the layer to be selectable and then you can select and delete them, similar to any other object.
Anyway, check these two situations and let us know if they was it.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I'll be checking this out later on. I'll let you know.
Andy Gaskin
Design Leader
Plastic Omnium Automotive Ltd
