env var, or Defaults setting for custom Attribute column in Asm Nav?
NX8.0.0, Windows 7 SP1 Pro 64-bit
We have part Attributes such as DB_PART_DESC and DB_PART_NO, etc, which we would like to display as columns in the Assembly Navigator.  This is very straightforward to do, by adding the Attribute to the Column list in the "Assembly Navigator Properties" dialogue.
However, this has to be done on a workstation-by-workstation basis.  I would like to be able to apply this setting for all workstations in a shared config file.
How would I go about doing that?
I am familiar with customizations to the UGII_ENV_FILE, similar to those described in threads such as: thread561-199574: Coustomising ugii_env.dat
RE: env var, or Defaults setting for custom Attribute column in Asm Nav?
I believe these settings are stored in the registry so if you willing to 'copy & paste' registry entries...
Of course, this would explain why there's nothing like variables or template folders where this stuff is kept.  Sorry.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Really? Bummer...
