Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
Adjustable/variable pressure relief valve upto 5000psiHelpful Member!
Optimustang (Mechanical)
4 Oct 11 17:24
My shop is building a hydrostatic test bunker for pressure testing compressor cylinders. We are planning to install a high pressure pump (Brand: Haskel) for this purpose. As a safety regulation we need to have a pressure relief valve installed on the cylinder.
We test cylinders at pressures varying from 500 to 5000psi, so I was wondering if there are any adjustable/variable pressure relief valves which I can use. For e.g. if I am testing a cylinder at 1500psi, I want to be able to set the relief valve at about 1510 psi or so.
Thanks for your help folks.
Helpful Member!  rustbuster (Petroleum)
7 Oct 11 14:12
I have never heard of an adjustible relief device with that wide a diffence. You will require valves for each pressure you test at.
7 Oct 11 15:02
Thanks for your response, I guess I'd stick to your suggestion but, I got 20 to 30 different testing pressures. I am wondering if there is any other way (a auxiliary setup) of doing this...
But thanks anyway. I thot I would never get a response. :)
mbt22 (Chemical)
9 Oct 11 5:19
Rather than getting the shop to reset and pop test an RV each time, how about a stash of 20 - 30 bursting disc set pressures?  Fit the correct one for your desired pressure.
As an alternative, a hardwired high pressure shutdown system for the pump, if that is your only source of pressure.  A SIL assessment to demonstrate that the trip is of higher reliability than a relief valve.  My greatest worry would be human error in setting the shutdown pressure for each test, but you would have the same potential issue with re-setting an RV each time.
Matt
Close Box
Join Eng-Tips® Today!
Join Us             Close
