Hidden Lines in Drafting
I know how to show and remove all hidden lines in a view.
But is there a way to remove one of the hidden lines, and keep all the others in that view?
RE: Hidden Lines in Drafting
Edit -> View -> View Dependant Edit -> Erase Object
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
In the view dependent edit dialog box, choose the 'edit object segments' option. Change the line font to invisible and 'trim' the small segment away.
Thanks so much.  You have helped me alot
