high temperature thread sealing compound
I need to seal a 1/2 BSP thread for a steam application.  Material is steel.  Temperatures will rise above 500C. Pressures up to 6 bar.
I am sure welding is best however I need a short term solution to keep me going.
RE: high temperature thread sealing compound
http://www.xpando.com/
Whether it works or not will depend on how skillfully you apply it.  Don't overtighten- leave enough in the joint to expand and seal.
You can try grafoil tape as well.
http://www.egcflexiblegraphitesolutions.com/html/
That'll work for SMALL fittings under MODEST pressures.
That assumes that the thread is BSPT taper, not BSPP parallel.  In the later case, you need a gasket.
