API To Balloon a Sub-Assembly
I have written a macro that I use to assign custom properties to the components that balloons are attached to in my assembly drawings.  I use split balloons, where the top is the detail number and the bottom is the drawing number.  I would like to be able to do the same thing with sub-assemblies.
I found a thread by Handleman thread559-197270: Select Parent Subassembly, where he wrote a macro to select the sub-assembly of the selected component in an assembly.  Does anyone know if this can be done in a drawing?
Below is the section of the macro where I find the components that the selected balloons are attached to.  After that I add the custom properties that I want.
Chris
For i = 1 To Count
        Set swNote = swSelMgr.GetSelectedObject6(i, -1)
        Set swAnn = swNote.GetAnnotation
        vAttEntArr = swAnn.GetAttachedEntities3 'Get the entity  (edge, surface, etc) that the balloon is attached to
        vAttEntTypeArr = swAnn.GetAttachedEntityTypes
        If IsEmpty(vAttEntArr) Then      'If the balloon isn't attached to anything
            MSG = MsgBox("Balloons Must Be Attached To A Part", vbExclamation, "Custom Balloons")
            Exit Sub
        End If
        Set swEnt = vAttEntArr(0)        'Entity the balloon is attached to
        Set swComp =swEnt.GetComponent    'Component the entity is part of
        Set swCompModel = swComp.GetModelDoc    'Modeldoc of the component
