API 650 Plate from coil
Does the code API 650 accepts plates from coil in order to be used for shell manufacturing?
If yes, in which condition ?
RE: API 650 Plate from coil
API 650 is silent on this issue, that I know of.  However in Appendix D there are a couple of questions asking about material from coil and the answers did not include any responses regarding the steel from coil.
I don't think the standard prohibits plate from coil; provided that the plate in question is produced in conformance with one of the specifications listed.
