Single Hydrant Flow Test
I need to get the available fire flow on a dead end line with one hydrant at the end.  At the tap of this dead-end line is a fire backflow preventer.  Since there is only one hydrant, we don't have a gauge hydrant.  The fire contractor did a "single hydrant" flow test, which I've never seen before.  Are these accurate?
RE: Single Hydrant Flow Test
This is sort of the procedure that I use to flow test the hydrants in our municipality and determine what color to paint them.
http://www.firehydrant.org/info/ftest1.html
Basically, you
- take static pressure
- flow hydrant
- take residual pressure
- take flow reading (pitot)
- calculate the max flow possible with hazen-williams equation.
Can use this online calculator on the same website
http://www.firehydrant.org/info/hycalc.html
