Relationship between Wavelength & Cable Length Formula
Is there any Wavelength(Lambda) to cable Length formula?
Relationship between Wavelength & Cable Length FormulaRelationship between Wavelength & Cable Length Formula(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Relationship between Wavelength & Cable Length Formula
I use .667 i.e 2/3 when I don't know. Use it for fault location in cables, usually. The 2/3 makes translation between us and m very easy.
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
In general, for TEM mode with homogenous medium outside the conductor:
u = 1/sqrt(mu*eps)
In a vacuum:u0 = 1/sqrt(mu0*eps0) = speed in vacuum = 3E8m/sec
In medium 1 with properties mu1, eps1:
u1 = 1/sqrt(mu1*eps1)
Considering mu1 = muRel1*mu0 and eps1 = epsRel1*eps0 (where Rel = relative), we can write:
u1 = 1/sqrt(<muRel1*mu0>* <espRel1*eps0>)
u1 = u0/sqrt(muRel1*espRel1)
Typically muRel1 = 1 when discussing cables (only not 1 for devices with cores). Then we have u1 = u0/sqrt(epsRel1) = 3E8 / sqrt(epsRel1)
The velocity factor mentioned above would presumably be 1/sqrt(epsRelative)
(2B)+(2B)' ?
I will mention an important assumption of my previous post "homogenous".
Strictly speaking, you could use the equation I gave only for 2 wires immersed in homogenous medium Eps1 in the region between the cables and inside the shield.
When you have non-homogenous medium, the situation is what Waddell (Transmission Line Handbook) calls quasi-TEM. He discusses a parameter EpsEffective which is somewhat of a weighted average of the various permeabilities present (air and insulation.
EpsEffective = Cactual / Cair,
Waddell analytically addresses twisted shielded pair in section 3.3.3. Even with simplifying assumptions it gets messy.
I think the easier approach is google for some thumbrules applicable to your twisted shielded pair cable type.
(2B)+(2B)' ?
should have been
in the region between the conductors and inside the shield
(i.e. the presence of air in addition to insulation in this space within the shield makes it non-homegenous.
(2B)+(2B)' ?
(2B)+(2B)' ?
If it's not listed, then contact the manufacturer and ask to speak with the applications engineer.
Or just use 70%.
