PDMWorks Highlighted Background
Is there a way to change or darken the background of the Vault highlighted color? It's hard to see especially when I drag the dock task pane my other monitior. I tried adjusting the contrast and brightness on the other monitor and does not help in the highlighted display. I know the answer will be probably be no, but have to ask. See attached example.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 Windows 7 Pro (64-bit)
Xeon CPU 2.53 GHz 6.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
