Lateral load capacity
I have a project of 3 basement + ground floor + 7 typical floors
the basement is at 15 meter depth i put my pile foundation at 21 meter from EGS. Total length of pile is 6 meter. I need the lateral load for this using Brinch metehod at 0.5 m pile diamter and 0.6 meter pile diameter. can anyone give me some sample coputation for this prblem.
UCS value = 13.1 kg/cm2
soil profile from 15 - 21 meter is rock composed of mudstone
RE: Lateral load capacity
Just for curiosity, Why does is it need to be necessarily using that method?
Your structure is multistory and hand methods should be verified by computer output. Also if this is your first time analyzing lateral loads, this is too complex a project-seek an experienced engineer's advice.
www.FoundEng.com
In the big scheme of things, you can approximate "C" by the value phi/10 where the value of C is never less than unity. Bear in mind the use of Cp requires that the pile-to-pile spacing in plan dimension is at least 3B, but should really be at least "C"B so you don't overstress the plane strain condition.
f-d
¡papá gordo ain't no madre flaca!
