Mate component on promote body
as you can see in the video attached, I'm not able to add mates on a component that was promoted for machining.
Where I wrong ?
On the promoted body there are welds.
The license is floating and now is busy by other.
Can this situation be the cause of this strange behavior ?
Where I wrong ?
Thank you...
Using NX 8 and TC8.3
RE: Mate component on promote body
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I don't want to move the promoted body and I know that the promoted body is linked for all by it parent.
I don't understand why I can't select promoted body face.
You suggest me to open an IR ?
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
I will try tomorrow to export for your examination.
Thank you...
as i understood from your video, you are using nx7. dont you affraid of using assembly constraints in nx7? assembly constraints in nx7 has some bugs if you are working with wave linked bodies (and I believe the same could happen with promoted bodies). try to swtich to the old mating conditions and then do your mates.
also you can check:
http://www.eng-tips.com/viewthread.cfm?qid=299606
