splitter 4 way
splitter 4 way
Hi
What is the best circuital solution to divide a rf signal with 800-2400MHz of BW and level of -30dBm in 4 ways with impedance in and out of 50 Ohm.
Thanks for reply.
Thanks for reply.
RE: splitter 4 way
ht
Choose your form factor (surface mount, box with connectors, etc.), then select "4-way" and "0°".
RE: splitter 4 way
If you need to design one, it's almost always three 1x2 dividers assembled together. You can find 1x2 divider designs in many places.
