pressure oscillations in a pipeline
Can someone tell me if pressure oscillations of the fluid being conveyed in a pipeline (like in slug flow) will induce vibrations of the line? (non-breathing that is)
thanks
thanks
RE: pressure oscillations in a pipeline
rocking and torsional modes are likely to be excited with potentially serious consequences. Unless your piping walls are standard or reinforced Reynold's wrap, shell lobar modes of the piping should not be involved with their response frequencies at least two orders of magnitude higher than 5-13 Hz slug flow excitation frequencies.
