2D array (matrix) in Fortran-Mex file
Hi all,
I am writing a FORTRAN code for a MEX (Matlab executable) file. I am facing a problem in defining the dimensions of the matrix. Following is the code which I have created.
C gateway subroutine
subroutine mexfunction(nlhs, plhs, nrhs, prhs)
C-----------------------------------------------------------
integer plhs(*), prhs(*)
integer pr_in
integer mxGetPr
C----------------------------------------------------------------
integer nlhs, nrhs, mxGetM, mxGetN
integer m_in, n_in, size
m_in = mxGetM(prhs(1))
n_in = mxGetN(prhs(1))
size = m_in * n_in
pr_in = mxGetPr(prhs(1))
C call the computational routine
call compute(%val(pr_in), size,m_in,n_in)
return
end
C============================================================
C computational subroutine
subroutine compute(in_mat, size,m,n)
integer size, i,j,m,n
real*8 in_mat(*)
open(100,file='matrix.txt', status='unknown')
do i=1,size
write(100,*) in_mat(i)
enddo
close(100)
return
end
In the gateway routine I read an input matrix as pr_in(I know that it will be a 2D array) and I want to write it in a file.
This matrix is passed to the computations array as a vector which means only one dim.
I want to change this 1D array in the computational routine to a 2D i.e. from in_mat(*) to in_mat(*,*) so that it can be called as in_mat(i,j) instead of in_mat(i) while writing in the file.
write(100,*) in_mat(i,j)
Would be great if any one could give me a hint.
Thanks.
integer pr_in
integer mxGetPr
size = m_in * n_in
return
end
real*8 in_mat(*)
do i=1,size
enddo
close(100)
return
end
Thanks.
RE: 2D array (matrix) in Fortran-Mex file
if you know that the array has 4 cols for example, you can read the entire vector and transform it to a matrix (with two for loops).
that's assuming that the vector read is like this [1,2,3,4,2,2,3,43,4,3...] and you know the nr of columns for the array.
TTFN
Chinese prisoner wins Nobel Peace Prize
http://www.nsc.liu.se/~boein/f77to90/c12.html
http://
h
TTFN
The problem I am facing here is, the input is in the form of matrix, for example [1 2 3; 4 5 6] is a 2*3 matrix. This will be read by matlab, but when it is transferred to to FORTRAN Computational routine, FORTRAN is only allowing me to define this as
real*8 in_mat(*)
But i want some thing link
in_mat(*,*) so i can index easily.
in the current situation if i give this input [1 2 3; 4 5 6],a 2*3 matrix
in fortran it becomes like a vector as [1 2 3 4 5 6]
thanks.
you only need to know nr of rows and cols and make two for loops to sort the data.
in_mat(nr,nc) ?
If that, somehow, does not fly, try this:
in_mat(nr,*)
If that does not fly, try declaring a small function that returns the single index needed based on the typical (i,j) index pair...like this:
integer function indx(nr,i,j)
indx = (j-1)*nr+i
end
and then you can access your matrix like
in_mat(indx(nr,i,j))
or, if you pass nr to the function some other way so that it does not have to appear in the parameter list, you can reduce your call to:
in_mat(indx(i,j))
remember, the function above is such because Fortran stores 2D matrices in COLUMN major format.
Also, the declaration above in_mat(nr,*) should work for the same reason...to declare assumed size arrays, fortran needs all dimensions but the last one in order to proceed.
thanks gsal, i will try these tricks.
in_mat(nr,*)
and it was working....
thank you so much...
