additional rebar for lateral loads
is it possible to design a column in a concrete moment frame by just designing it with Dead load and live load then just add rebars at column-beam joints for lateral loads, i.e. seismic loads? why or why not?
RE: additional rebar for lateral loads
Unless you are doing an unfactored design, such as WSD, why would you want to do it differently?
Mike McCann
MMC Engineering
But design is not just about forces and stresses. It is about practicality of construction, so your suggestion has little merit.
There are a lot of traps for young players in designing the joints in concrete moment frames. For that reason, most of us old players avoid moment frames.
