Roof Slab for underground structure
How soon can the formwork for the roof of an underground vault be removed and how soon can loading be allowed on top of it? This structure is an underground vault with dimenstion of 12'x12'x12' with thickness of 10" for all elements w/ 35MPa concrete.
RE: Roof Slab for underground structure
In any case, it's unlikely you would have to wait a month, even with normal concrete.
Mike McCann
MMC Engineering
And if you are putting in soil and compacting it, I assume the loading is going to be close to the full design load from the compacting process!
Elite Concrete Restoration, Inc.
http://www.eliteconcreterestoration.com/
On Time, On Spec, On Budget
When full strength is reached (as determined from samples) remove temporary propping within.
