Joint between hardened concrete surfaces
We are building a 30-foot underground concrete trench box for a utility service with dimensions of 3'x3'. We will have a monolithic pour for slab-on-Grade and walls. The top slabs will be precast and lowered on top of the walls at the end of project. A notch will be provided on top of walls so that when precast lids are lowerd on top of them, they can be locked in place. Do I need to provide any type of expansion joit board or membrane between walls and precast lids? Also, should I provide any expansion board between the three precast lids, and what material do I use to waterproof these joints?
Thank you in advance
RE: Joint between hardened concrete surfaces
htt
