Can't remember how to calculate an ARC LENGTH in C/K99
I am trying to remember how to use C/K99 to calculate the distance between two points on a circle. The circle is Ø1.16250" and the circumference is 3.625". The two points are located 129.611° apart from each other, so how do I do this and what IS the arc length between the two points? Thank you!
RE: Can't remember how to calculate an ARC LENGTH in C/K99
Verify, Distance, 2 Points is the easiest method for the distance measurement.
Thank you, again for such a rapid response!! Warmest wishes!
Gene "2old2" Davis
It's a GOOD DAY!!
Gene "2old2" Davis
Best wishes!
Gene "2old2" Davis
