component selection
component selection
Hello.
I import models from diffrent cads system but generaly that models consist plenty of screw, washers, nuts, small shafts, .... and so on. I dont need this small components and I would like delete it after import model. Can I select all componets that mass is lower than 1 kg or volume is lower than 100mm3 (for example)?
Best Regard
Mat
Best Regard
Mat
RE: component selection
I dont know what type of license I have because I am not administrator but as I remenber there is "advanced assemblies" toolbar. Do you know how to select small parts in big assemblies? :)
Mat
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Now I know how to use component Groups, This is really usefull function. It Works perfectly!
Thank You.
