Radial projection
Radial projection
I am self teaching myself on flanges; does the term ''RADIAL PROJECTION'' refer to an imperfection only running perpendicular across the flange face? If so, my I have a layman's definition?
Thank you.
Thank you.
RE: Radial projection
Go here and read what may be your answer.
ht
"A radial projection shall be measured by the difference between an outer radius and an inner radius encompassing the imperfection where the radii are struck from the centerline ofthe bore."
Ted
