HELP! Demagnetization
My questions are similar to one in another thread. In my application, I'm using two rare-earth magnets inside a shaft, same poles touching to repel each other (thus moving a rod inside the shaft)and then bringing them together again (no impact), then repelling, over and over...
1)Should I expect the magnets to demagnetize or even one of them reverse poles over time?
2)If I find the rare-earth magnets to be too strong (too hard to bring together) for my application, could I use ceramic or ferrite magnets instead, or would these be even more subject to demagnetization or reversal?
Many thanks in advance.
RE: HELP! Demagnetization
Temperature is one variable to consider. Any permanent magnet becomes demagnetized quicker as you approach its Curie temperature.
(2B)+(2B)' ?
http://en.wikipedia.org/wiki/Neodymium_magnet
(2B)+(2B)' ?
