Shot Blast Profile Deterioration: Humidity v Time
Hi guys,
need a little advice here. We are having a little difficulty with owners reps at the moment over the time taken from blasting sections of steel to the application of primer coat.
The steel is bog standard - nothing special. Surface finish is SA2.5
The general rule of thumb (as I understand it) is that at 85%RH, you have 4 hours before the blast finish deteriorates. We are currently working on averages of 50-60%RH.
I am assuming that the relationship between the two is exponential, the question is, does anyone have anything concise on this please? Or can anyone tell me how long I have at, say 60%RH
We are using big de-humidifiers, but we are working on a dock, so almost impossible to reduce the RH% any further.
Declan
RE: Shot Blast Profile Deterioration: Humidity v Time
my understanding is that you need to watch for rust back. the blast profile will only change with the appearance of contamination (rust).  SA2.5 is the same as SSPC-10 NACE 2(I think).  the other requirement to watch is the dew point.  u need to be at least 5degF above the surface being blasted.
