NXOpen.BlockStyler.UIBlock
Hi all,
I'm new to NXopen and I have a quite silly question; how I add items in a listbox and bitmaps in a dialog created by the blockstyler?
I thought the obvious answer will be something like this:
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is list_box0 Then
Dim list_box0Props As PropertyList = list_box0.GetProperties()
list_box0Props.AddItem("value")
End If
But I'm getting the error that "AddItem" is not a member NXOpen.Blockstyler.Property. What I'm doing wrong?
Zoes
Try
End If
Zoes
RE: NXOpen.BlockStyler.UIBlock
You are close to your goal. After calling GetProperties() you will need to call SetStrings(), e.g.
PropertyList.SetStrings("ListItems", <your list here>)
where <your list here> is of type String(), e.g. an array of strings you wish to fill the list with. "ListItems" is the property keyword used by the ListBox to get/set the items in that list.
Therefore your example should look something like (untested!):
CODE
Dim listbox0Values() as String = {"value"}
list_box0Props.SetStrings("ListItems", list_box0Values)
End If
Marc
NX Software Developer
The error now is that listbox0Values needs to be declared.
That's confusing. I can see that the listbox0Values is String, what more does it need?
CODE
Marc
Marc
You will need to place the code in initialize_cb(), which will fill your list box as soon as your dialog appears:
CODE
Try
group0 = CType(theDialog.TopBlock.FindBlock("group0"), NXOpen.BlockStyler.UIBlock)
label0 = CType(theDialog.TopBlock.FindBlock("label0"), NXOpen.BlockStyler.UIBlock)
list_box0 = CType(theDialog.TopBlock.FindBlock("list_box0"), NXOpen.BlockStyler.ListBox)
Dim list_box0Values() As String = {"value"}
Catch ex As Exception
'---- Enter your exception handling code here -----
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
End Try
End Subx
Marc
Ps: to upload an image in the "label0", will follow similar code?
CODE
e.g.
CODE
Marc
Thanks Marc
I would appreciate it if you thanked me for my valuable post(s) by clicking on "Thank MarkyMON for this valuable post!" :)
Marc
Marc
expression0 = CType(theDialog.TopBlock.FindBlock("expression0"), NXOpen.BlockStyler.UIBlock)
Can you configure it to load the "thickness" expression for the user to edit from there instead for opening it from Tools -> Expressions?
CODE
Marc
This is what needs to happen:
1. Find the work part's thickness expression. This will be a NXOpen.Expression object.
2. In the initialize_cb(), the expression's ExpressionObject needs to be set the to the work part's thickness expression.
According to the NX help:
This means that any changes to the block (e.g. change of value) will also change the value of the expression (in your case, thickness).
Please send me the code so I can implement the changes.
Marc
Tried to call the expression like this and attribute its value to a string variable:
Dim expression0 As Expression = CType(workPart.Expressions.FindObject("thickness"), Expression)
Dim thickness As String = expression1.Value.ToString
Still I'm not sure if I'm in the right track.
Here is the code.
CODE
Try
Dim thicknessExp as Expression = CType(theSession.Parts.Work.Expressions.FindObject("thickness"), Expression)
If thicknessExp IsNot Nothing Then
expression0.GetProperties.SetTaggedObject("ExpressionObject", thicknessExp)
End If
End Try
End Sub
From GTAC:
It basically means that if you have a standalone expression and it is not referenced by another expression, then that standalone expression is deleted when clicking OK or Apply in the dialog.
Marc
I'm not exactly sure what you mean. It should depend on how the expression is being used in the (work) part...
Marc
In order for the new value to be applied to the work part you need to go Tools-> Expressions -> Apply, then you can see the workpart increase size.
Is there any code line to update the workpart based on the current expressions's values? Update (regenerate) the display?
Marc
I wonder if it has to do with something like that:
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Update Expression Data")
Marc
Marc
Marc
Marc
nErrs1 = theSession.UpdateManager.DoUpdate(id1)
