8" NSF 61 Full (80%) Port Valve MJ
I am looking for an 8" NSF 61, full (or 80%) port valve, like a ball or an eccentric plug valve with Mechanical Joints.
I found tons of =< 4" NSF 61 brass/bronze ball valves and tons of non NSF 61 Stainless Steel 8" ball valves.
I found one 8" eccentric plug valve
h ttp://www. gaindustri es.com/MPr oducts/Bul letins/Ecc entricPlug Valves/GAI _PV517.pdf
but it has an epoxy coating on a ductile iron body. I have a concern for the long term durability of the epoxy coating, one little nick & I have accelerated corrosion.
This is for a potable water line, that should be "piggable".
Any suggestions would be most welcome.
h
Clifford H Laubstein
FL PE 58662
RE: 8" NSF 61 Full (80%) Port Valve MJ
FL PE 58662
2. Type V132 Resilient Seated Gate Valve 3 Inches to 20 Inches, for Buried Service:
a. Iron body, resilient seat, bronze mounted, mechanical joint ends,non-rising stem,
in accordance with AWWA C509, 2-inch operating nut, design orking water pressure 200 psig
for 2 inches through 12 inches, full port, fusion epoxy coated inside and outside per
AWWA C550. NSF Standard 61 certified.
b. Manufacturers and Products:
1) M&H Valve; AWWA C509.
2) U.S. Pipe; Metroseal.
3. Type V137 Resilient Seated Gate Valve 4 Inches to 12 Inches, for buried service:
a. UL Listed and FM Approved for fire protection, iron body,
resilient seat,
bronze mounted. Provide mechanical joint ends, nonrising stem, 2-inch operating nut,
in accordance with AWWA C509, design working water pressure 200 psig, full port,
fusion epoxy coated inside and outside per AWWA C550, NSF standard 61 certified.
Provide indicator post flange and indicator post assembly with lockable handle, where applicable.
1) Kennedy Valve; Ken-Seal II.
2) M&H Valve; Style 4067.
3) Mueller; P-2360.
FL PE 58662
FL PE 58662
