Glass Structural Sreength
I am checking the design of a 3/4" glass panel. If any one has bending, shear values and E for glass please let me know. One reference is ASTM E-1300. I do not have it.
RE: Glass Structural Sreength
Call a mfg or Google it!!
ATEM E-1300 gives allowables for annealed, heat strengthened, and tempered for the 8/1000 probability of breakage. I believe annealed is higher than 1000.
Also, I might be mistaken, but I don't believe the duration of loading affects the strength unless you have laminated glass (because of loss of composite behavior with longer duration loading).
Do you have a better resource than ASTM E-1300 for glass design?
