pipe span design for weight supports
Hi;
In piping support design specs & codes we see tables of pipe spans, as distance between two weight supports in a straight horizontal line cannot exceed this amount. Now the question is if the line is not straight and there is a change in the direction of line (for instance by elbows), what amount shall be used for pipe span.
RE: pipe span design for weight supports
Can't put my finger on the text....
Also, see:
http://www.eng-tips.com/viewthread.cfm?qid=49424
Just look down the line, with your head at the top or bottom of the installed line. You can easily see if the droop exceeds 1/2".
