ASME VIII UCS 66 Curves
Does anybody know how I can EXTRAPOLATE Fig UCS-66 Curves upto 250mm thickness
RE: ASME VIII UCS 66 Curves
Extrapolation not necessary; final thickness notation at bottom of chart is >/= 75mm.  Because it flatlines at 75mm, use that value as appropriate for your intended material/thickness..
Elise, perhaps you had better read UCS-66.
Odd question for the forum.
Mike
