Editing an existing hole.
After creating a general hole inside NX5, why can't I change the type of hole to a threaded hole? Is this something that our CAD administrators have locked down? Thanks in advance for any help.
RE: Editing an existing hole.
I don't think you will be able to change the hole type until NX8.
Yes, this limitation is cut off in NX8.
I suggest you install NX8 and you will see the light.
NX8 is a very good implementation in all modeling feature.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
