ceramic insert geometry description
Hi everyone, I ran across the mention of ceramic insert geometry in the form of a string of numbers separated by commas.  But I am not able to find what those values correspond.  My example that I see in a pdf on Machining Forces and Merchants Circle:
"... a ceramic insert with geometry 0deg,-10deg,6deg,6deg,15deg,75deg,0mm..."  (deg=degree and mm=millimeter)
Thanks for any feedback
Dave Harhay
Fives Bronx
