Explosive Decompression on a Composite Rod
Dear All,
Does anyone have any experience in how a composite rod (aramide or carbon with a poly or epoxy resin) of about 4-6mm diameter will behave when exposed to explosive decompression. And when I say explosive decompression I mean from 10K psi to atmospheric in well under a second.
It will be exposed to various gases such as CO2 at high temperatures for extended periods (4-24 hours) before the pressure drop so there will be plenty of time for the gas to permeate the rod.
Any feedback will be appreciated.
John McGrath
John McGrath
