Restrictive Venturi - Anyone have information about these?
Need to design a restrictive venture, regular orifice wont work as there are solids. Does anyone have a way to calculate the dimensions? I am unable to find any equations
THanks
THanks
RE: Restrictive Venturi - Anyone have information about these?
Venturi's are great at pressure recovery; not so good as restrictions (for the money). Folks normally use them to induce another stream into the main stream.
At least that's my experience.
Good luck,
Latexman
David
I would like to be able to build one and then use the calculations to figure out what pressure drop is caused by that particular design.
Good luck,
Latexman
To continue this fascinating guessing game....
By "a regular orifice wont work as there are solids" do you mean the orifice is unacceptable because it will wear too quickly, OR do you mean that the regular orifice will clog ?
If you are concerned about accelerated wear, you might consider a ceramic orifice.
Otherwise, all of the solutions proposed above will eventually clog
Good luck,
Latexman
