estimate force for spining machine
Dear All
Thanks inadvance for your kind attention.
Is there any one to show me how to estimate force for spining forming a metal plate.
As you know, heads of pressure vessle are elleptical form.you will find in attchment a sketch to clarifing force and mechanism of forming.
kind Regards,
M.Maleki
http:/ /files.eng ineering.c om/getfile .aspx?fold er=39faaad 9-c1bf-431 c-a3b7-f91 5ca6d6630& amp;file=F ORMING.pdf
kind Regards,
M.Maleki
http:/
RE: estimate force for spining machine
Max. thickness after forming 32mm,for before forming I think is related to machine e.g. size of roller, number of rolling to get final radius.
M.Maleki
As attached you will find sketch related to knuckle and crown radius,
This will be cold formed and material is carbon steel.
I think heat treatment is used for 38mm and above in thickness.
thanks for your kind corporation,
M.Malkei
