Contact analysis of lifting pin in hole
I am trying to set up a contact analysis between a lifting pin and the inner surface of the lifting bracket hole, both have different diameters.
When setting up the connection 2 contact areas must be defined. Is this the contact area before material deformation begins? Bearing in mind the initial contact point at the tangent of 2 cylinders of different diameter will be infinitely thin and will only become an area with thickness when both parts begin to deform.
Has anybody come across a similar problem and if so how was the contact area set up?
Inputs are as follows:
Radius of pin - 60 mm
Radius of lifting bracket hole - 62.5 mm
lifting load - 1 000 000 N
RE: Contact analysis of lifting pin in hole
corsa007,
I am pretty sure this is a common form of contact similar to a bearing analysis.  Here is a document posted in the PTC communities forum that really helped me out and hope it helps you out.
http://communities.ptc.com/message/157098#157098
Good luck,
-J-
