Sheet Metal question
Playing around with sheet metal part of NX7.5 and 8.0. Once I create a tab (flat sheet of metal) it will not let me input a thickness or bend radius. The thickness stays at 0.100.
I am trying to create a jacketed box (a box with insulation around it and another box to cover the insulation).
Thanks in advance!
Thanks in advance!
RE: Sheet Metal question
Preferences -> NX SHeet Metal -> Part Properties
...and set it there.
However, if as it appears that you've already created something an NOW wish to make a change, just donble-click the feature of interest and when you see the 'Thickness' or 'Bend Radius' dialog and its non-editable parameter just select the little f(x) to the Right of the value and choose the 'Use Local Value' option and now you can enter any value you wish for the that feature (note that while the 'Bend Radius' can be edited on a feature by feature basis, in the case of 'Thickness' editing the 'Tab' will effect the thickness of the entire sheet metal model, as one would expect).
Anyway, I hope this helps.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Individual bend property changes can be done for any bend in your part with "resize bend angle", "resize neutral factor" and "resize bend radius" That way you have full control of the flat pattern that you're after in the end.
We continuously do that now but we use a custom Knowledge Fusion program to do it automatically for us using our bend knowledge (xls tables)
2x NX 7.5.4.4 mp2 and NX8.0.0.25 Mach Design
1x Solid Edge ST2
when I create a new sheet metal part and create a tab. It's thickness is indeed the same as described in
however, when I go to tools -> expressions and change the thickness there, it does not alter the thickness of the tab. Is there a way to make this work?
(I have to go to the tab's properties, and choose "formula" for it's thickness, where I can select the "Sheet_Metal_Material_Thickness" parameter)
NX 7.5
Teamcenter 8
The value of "Sheet_Metal_Material_Thickness" expression always comes from the value you type in under the sheet metal preference menu. You can delete the formula and replace it with a value however. But I believe for keepings things clean and organized it is better to change material thicknesses in the global settings.
1x Solid Edge ST2
1x Solid Edge ST2
NX 7.5
Teamcenter 8
