Question Regarding Electro-Mechanical Relay
Currently we have experienced a slower than optimal reject rate on one of our machines. The reject station is operating an air solenoid and was controlled by an output module. As an experiment the module now controls a mechanical "dry contact" relay which then activates that solenoid. Both configurations where watched using a scope meter and found that the relayed configuration was operating earlier and for a longer period of time than running straight from the module. This cause the reject rate to operate at a much better pace. Does any one have an explanation as to why this maybe be?
RE: Question Regarding Electro-Mechanical Relay
BTW, is it a sheet cutter? Jagenberg, perhaps?
Gunnar Englund
www.gke.org
Bill
"Why not the best?"
Jimmy Carter
