Gasket Material
Gasket Material
Gasket Material
Hi to All
The answer to the following question shall be greatly appreciated:
I am trying to install a SSDS (super Duplex)2500# RTJ flanged madular DB&B valve on a Flow Line using a 6"x 2"-2500# RTJ Nipoflange in A350 LF2 material (Flow line is API 5LX52N), now, What type of Gasket is the most appropriate between these two diffrent type of flanges ?, I am contemplating gaskets of type Octagonal Ring AISI 316 R26! will this be OK with regards to Corrosion?
Thanks a lot
RE: Gasket Material
Thanks Steve, no the line is not Subsea but it is on a platform at sea !
RE: Gasket Material
The ring will but the carbon steel groove might not.  Is it being given an overlay?
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
RE: Gasket Material
No, the Nipoflange is a standard 2500# RTJ and does not have any perticular weld overlay, if you mean the surface of the flange grooves has been treated. Do you mean the ring might corrode ?
Thanks.
RE: Gasket Material
No - I mean that the carbon steel will corrode and the seal will be degraded.
Steve Jones
RE: Gasket Material
Hi
I found out (in addition to your comments)that HARDNESS of the gasket in comparison with the 2 different type of surface material of the flanges, play a significant part when it comes to corrosion and leakage.
Thank you
RE: Gasket Material
Hi pipeneer, if your worried about corrosion, you can get specific gaskets that aid the joints resistance to corrosion.
Flexitallic make a flange rescue gasket in an RTJ form to fight corrosion.
http://www.flangerescuegasket.com/products/flange-rescue-gasket-ring-joint
Pikotech also make there VCS gaskets
http://www.pikotek.com/ViewProduct?product=300&region=1
There are a few others if you Google. Also due to the difference in metals across the flange ensure you get a full insulating kit for the whole joint (insulating bolt sleeves + washers), this will prevent galvanic corrosion.
Disclaimer:- I work for Flexitallic, but I am not a salesperson so am not promoting anything just trying to help.
AbyssUK
